AKRAY4PLAY
- Joined
- Oct 14, 2001
- Messages
- 584
- Location
- Wasilla, Alaska, U.S.A.
- Corvette
- '77 L-82, black on black. Full mod 406 small block
fellas,
i need to pick everyones brain on this one. i finally, after two years of hell, got my 406 completed and dyno tested. it makes 575 hp peak and 525 ft/lbs peak. i plan on running a 2400 stall converter with 3.70 gears for a fun little street car. at 2400 rpm the motor makes 418 ft/lbs. the more people i talk with, the more i get confused with what the rear end's life expectancy will be. i don't have information from vette guys that are running the same power my small block generates. i called tom's differentials and priced what they suggest. modified carrier with 12 bolt parts, $2350, and 1480 series half shaft kit, $2150. five grand is a lot of money to throw away if i truely don't need the stuff, i'll buy it if i need it. i suspect i will have to beef things up a bit, but five grand worth?? i know you guys out there with mild big blocks are running similar numbers. what are you doing to keep things together under the rear?? i have the vette brakes performance plus suspension kit installed and the tranny is already built. i get off work wednesday, and have a few last minute things to wrench on before i hit the key thursday afternoon. i would really hate to destroy the car on the first day out. thanks for all your input in advance, with everyone's knowledge this will have a happy ending!!
thanks again, brian
thanks again, brian
