black_81_vette
Well I dont know if I messed up but here goes.When I put my engine in and installed the clutch assembly I may have messed up.When I shift the car into gear and depress the clutch {engine not running} the rear wheels move still even the clutch pedal is pushed to the floor.My question is, if I by mistake put the clutch disc in backwards will it cause the clutch not to disengage?When I put the linkage back together all of it went back together with no trouble.At the moment im turning the engine by hand while sombody depresses the clutch and the wheels still turn,and the clutch was the one that was in it and it was fine before.Im having more trouble than this worth.
