76okievette
OK, I need some help, I have installed my half shafts, 1976 L-48 Auto, with the new spicer jerkless u-joints. The problem is the u-joints don't seem to fit in the flange coming out of the differental. The flange has two cups that the joints slip into and the joint caps fit right in. The other two joint caps, the ones that get the u-bolts over them don't fit between the two small ears, there are just two small ears on the flange coming out of the differental that the joint caps fit between then the u-bolt goes over the top and bolts them down. Well I could not get the U-joint to fit exactly between those two ears. One side is inside of the ear the other is about a sixteenth of inch to long and the joint cap won't seat completely inside of the ear. The U-bolt holds the joint in place and is tourqed correctly I am just concerned that it does not fit in between those two ears/tabs. I had the u-joints installed on the half shafts by a very honest corvette place so I assume they are the correct size. Also when I was installing the half shafts one of the u-joint caps did come off but I reset all the little bearings and but it back on it, seemed to slip right on. Please let me know what you think, do I have to remove the half shafts again or do you thing they are ok?
