I have a 64 vet 327 365 hp I have to pump the gas 10 times or more to start it when cold ???
Check that the choke is closing all the way when cold on the first pump. Also check that you are getting a strong squirt out of the accelerator pump, plugs are clean and gapped right, points are in good condition and dwell and timing are set right. Check condition of the plug wires and that you have a good strong spark at the plug. A weak spark could be a weak coil.
Tom
Tom
First of all welcome aboard we're glad you've joined usOn you problem does this 327 have a Carter AFB carburetor; or what make is it? Sounds for sure like you have a choke problem if this problem is when it's cold only
if it is burning rich or lean you may have a float problem too. Again if it's just when it's cold would contend a choke problem, assume this is automatic choke not a manual?
-Bill
