9
90Callaway
HELP!!!!!!!
I give up... can't get the damn thing off. Chris or Luigi, I think maybe you guys have done this with your verts? I did not put mine on so I can't figure out how to remove it.
I have all the bolts out - two in the windshield header and all the ones on the two brackets on the mounting points behind the doors. I just can't get the pins out of the two mounting points where the soft top would clamp down to the rear deck.
I was assuming I'd just pull the cable release and they'd just pop out like the soft top does... no. Then I figured I had to back the nuts off the studs and lift the top off that way... no. The nuts won't back off all the way they get hung up. I give up.
Unlike my usual mode of operation I walked away and called it a day. I'd usually keep getting bigger hammers until I broke something. Actually, I can thank my girlfriend for being the voice of reason.
She suggesting that I ask for help... a very non guy thing to do!
