93Rubie
Ok, I got two thing going down here:
1. Has anyone ever replaced your harmonic balancer. FSM says to raise front of engine to access the balancer. That is fine and dandy, except where do you lift. Oil pan is off limits. The only thing I can think of is to jack up on the transmission bell housing. Obviously, with the motor mounts unbolted. Will that work??
An alternative idea I had was to use a cherry picker and lift up on the engine, by wraping some ratchet straps around the exhuast manifolds. Would be nice if the LT1 had some engine hooks on it.
2.I have what appears to be hard water/mineral deposits mostly on my hatch. Is there a good way to get rid of these so my glass is crystal clear. I have l cleaned it inside and out with regular glass cleaner but to no help.
I was think that clay bar might work, as it works on the paint at removing deposits of "stuff." What do you think?
