Harrys Kid
Harrys Kid
New member
NJ
99 Magenta red coupe
having trouble with drivers electric window. Replaced motor now window gets stuck in down position every couple of weeks. One cable seems to tighten up to much. Ant tips on adjustment.
You will need to pull the door panel off. The window is hanging up on something at the bottom.
Have the door panel off. Seems one of the cables tightens up as the other side loosens Springs entering the mechanism get tighter and looser
Welcome to the Corvette Action Center. If you haven't already done so, you may want to post for help in the C5 Tech forum here.
Welcome to Corvette Action Center
Welcome and you would think there would be something pretty evident after you take the door panel off; have you done this yet;shrug
-Bill
Welcome to CAC!!!!:thumb
ENJOY!!
Harry's Kid
Have had the door panel off many times. Is off now. Can operate window properly. After a few weeks window gets stuck down. I open up the door and remove glass and it starts working. It is a new motor
Weird; not a ground problem is it ;shrug
-Bill
