Does anybody know if the hazard flasher button mounts to the turn signal switch? I can't find a listing of a separate switch and the button came off. Can't tell where it mounts.
If my memory doesn't fail me the emrg. flasher switch is part of the signal light switch .
Usually a small threaded stud protrudes from the column or just inside of the mounting hole.
My flasher button is located just below and forward of the ignition switch. The hazard flasher is connected to the turn signals according to the FSM on the column connector...hope that helps
