Head gasket on right side blown on my 56-57 motor
  • Thread starter Thread starter Big D
B
Big D
Just picked up my 57 vette, she looks great but was not running, replaced all ignition components and cleaned out the carb and got her purring, however, I noticed steam or exhaust coming out of the right side near the heads, then the car overheated, I looked at the oil and it was getting funky, thought the overheating was due to a bad thermostat, so I replaced that as well, she ofverheated after I shut her down and I saw steam rising up from the oil filler cap.
I am not a happy camper, how hard is it to pull the top off this baby and replace the head gaskets? Since the engine is nor original, I would not want to go into a complete rebuild if at all possible, what are your thoughts?
It could be as simple as a head gasket, or as costly as a cracked head or block.
In any event, if there is antifreeze/water in the oil, you've got to deal with it immediately.
A head gasket change is not too difficult, assuming you have some basic mechanical experience, but a torque wrench and proper procedures are called for.
After removing the head, you might get someone with engine experience to look things over before buttoning it up again.
Good luck.
67heaven is right - do it now. If you dont see a problem trail on the head gasket, have the head magnafluxed to be sure it isn't cracked. If the head is OK and the leak is still there after you install a new gasket - the block is the likely culprit. Change the oil before restarting after the gasket change. Change the oil again, if the leak is cured by a new gasket - after you get the engine good and hot. Oil is cheaper than everything is protects.
