Crimson Thunder
- Joined
- Dec 16, 2001
- Messages
- 814
- Location
- Orange Park FL USA
- Corvette
- 1970 Marboro Maroon Convertible
I'm finally about to start my top end rebuild on my Corvette.(one more small obstacle to overcome) I currently have GM crate motor #12356644 (300 HP) in the car now. It has 9.1:1 compression with 64cc heads #14096217. I am replacing those heads with a set of pre-eliminator AFR 195 heads which also have 64cc chambers. AFR recommends Fel Pro #1003 head gaskets with a .041 compressed thickness. I am looking for something a little thinner that still is compatible with aluminum heads( i have no idea what gasket is in there now, i hope it is more than just a steel shim).
Do you guys have any recommendations on which gasket to use? Thanks in advance.. Craig
