eoseitz
I've been posting a lot lately, but with the warm weather I've had a lot of time to work on the 74. I was wondering what some of you would suggest for a good head upgrade. My car has had the motor swapped out. It's a 76-77 LM1 out of a camaro. The specs are below:
The previous owner installed an Edelbrock performer intake, performer 650 carb and possibly a mild cam. I'm not sure of the cam size. I recently installed a new HEI tach drive distributor which probably won't make much of a difference.
I'm guessing I want to get 202 intake 160 exhaust to get better flow. The stock heads are 75.47cc so a smaller combustion chamber of maybe 64cc would up the compression and add some decent horsepower. I honestly don't know what the exhaust runners are for. Any info on this? I'm about to order some headers to reduce any bottlenecks in the exhaust system. I'm running straight pipes back to resonators.
What would be the best brand of headers for a resonable price? I'm wanting to get into the 350 HP range. My stock LM1 is only around 160-170 HP. I've heard votec heads are pretty good, but I already have an intake and valve covers and carb and don't really want to buy new ones. Also, would I need a more aggressive cam for heads in this range?
Thanks for any help.
Block | 3970010 | 2 bolt main | |
Crankshaft | cast iron | ||
Cylinder Head | 333882 | 1.94/1.5" Valves, 75.47cc | |
Cam | 14060651 | ||
Intake | 14014440 | ||
RH Exhaust | 346248 | ||
LH Exhaust | 381863 | could be 361863 |
