Pac Man, just installed:
Dynatech supermaxx system with corsa indy's, damn! Worth the bucks. Had it done in Tampa at Rev Extreme. Had a Vararam installed at the same time, and a tune. Before, stock rwhp around 285. After bolt-ons described above, left there at 325 rwhp and 340rwtq. so, in my case, about 35 more or so. What really improved was not so much the peak hp, but the torque starts low, and hard. She really pulls now. If i go with heads and cams later on, can figure on another maybe 75 more? The car is still as drivable as stock, but when you stomp on the pedal, sweet music!! Total cost, around 2,500 if you install, then about 500.00 for the tune. If a shop installs, then around 600.00 more for that. Tuning is not necesary, but beneficial. So far, not one code or error message on the dic. Hope this helps.......
Later, Herbie
