Alrighty then, I'll wing it
Two screws (not really screws, they are torx heads, like sockest that a torx screwdriver fits into, possibly #15, but not sure on that). Spray the plastic screw shafts they are attached to liberaly with WD40 prior to trying to move them. They are plastic and therefore brittle and frequently break. Just rock the tool back and forth until the mechanism starts to move, it'll take a while and maybe a few shots of WD40.
One accessed from the inboard side ( you are looking out from the centerline parallel to the front of the bulb) of the headlight housing (easier if you just remove the shroud surrounding the sides of the light assembly, three phillips head screws), that I think controls the horizontal (side to side) adjustment.
One accessed from the front outboard side (you are looking perpendicular to the front of the bulb, on the outboard side) that controls the verticle (hieght) adjustment.
This is not something that is done that often, so people may not remember which does which
But if you use the WD40 and a little caution, you can figure it out yourself pretty easily.
To adjust them properly, you'll need to search the forum or google for the whole procedure, I cant recall it well enough to tell you how to do it exactly.
Me, I just needed them a little higher (they didnt look far enough out ahead of me at night) so I parked 25 feet from a wall (the mall at night is a good place) and put tape on the wall at the center of the beam pattern (cover one light at a time with a towel as you adjust the other one).
Don't know if mine are adjusted exactly right, but no one is flashing me and I can now see where I'm going.
Good luck.
