If the 86 is like my 92, yes.
There are 2 bolts/nuts front and rear on the headlight cover that can be loosened to adjust the position of the cover. You'll need to remove the headlight fairing to see them and you may need to remove or loosen the whole headlight assembly to get the loose first. One they are loose, with the headlights off and down, you can adjust the covers position and then tighten them back down.
Anyone done this recently? It's been a couple of years since I had mine off and looking at them.
