Jon S
I understand there are three adjustments for the headlight door:
The doors have (3) adjustments
1. Stroke..This is the threaded rod exiting the air motor to the pivot pin (this is NOT used as a limit position) When this is set proporly the head light door will move more up (more than you need) and down further (than you need)
2. Upper limit... This is a bracket located on each headlight door (*looks like a hockey stick with a hex bolt threaded into the end (oposite the door) and the fender side of each bucket. The hex bolt comes in contact with the body when its in the upper position. This is what you adjust to get your door to stop at the position that your bezel is flush to the body. This is a hard bolt to get your wrench on but be patant and you will succeed. ( you might have to lower the door manually and adjust and open up door to check adjustment.
3. Lower Limit....This is a hex head stud (I think 5/16" dia) that is sticking down at the pivot point of the knockle that pushes the door up and pulls down. once you have the up set you can set this when the door is all the way down. Keep adjusting until the door is mostly flush with body.
Does anyone have a picture of 2. - Upper limit adjustment bolt? I have removed the housing cover and stared for over 1/2 hour but could not find the bolt in question for the "up limit" adjustment. My right light cover goes up a spec too high and I would like to adjust it. The down adjustment is perfect and that large adjustment bolt is easy to locate.
