John Robinson
Gone but not forgotten
Recently the right side headlight on my 93 would not go open all the way so I jumped to the conclusion that I had bad bushings. I removed the headlight and opened up the case to replace the bushings only to find that they were as good as new. In looking around the area of the headlight here is what I discovered.
This clip that holds the tube to the inner fender had come loose and moved down the tube. This allowed the tube to flex towards the tire.
This was just enough to allow the headlight to get caught under the clip and not rotate open.
As you can see when the clip is back in position the headlight can not get hung up on it.
So for all you in the future that have headlight problems on the right side you should look for this clip having come loose and slipped down to where it catches the headlight.
