T
tonybabb
Hi,
The passenger side headlight often won't raise on my 89 coupe. I turn the little black knob on top of the headlight motor a couple of turns and then it opens fine. The knob is often very tight. Could the motor be going past it's normal stop position? Is this repairable or do I need to replace the motor? I replaced the 3 plastic rollers and upgraded the gear to a brass from plastic a couple of years ago on both headlights and everything was fine. I've been having this problem for a while now and it's driving me nuts !!
Thanks for any advice.
Tony
Tony
