Headlight switch removal
  • Thread starter Thread starter tcarollo
T
tcarollo
How do you get the headlight switch off of the drivers side dash pad. I've taken out all the screws I can see.
Thanks, TC
first you need to remove the light rod. You need access to the rear of the driver side panel. once you can see the rear of the light switch there is a spring loaded pin which you need to press to remove the light rod. Once the rod is out of the way there is a isside nut which you need to remove with a very large screwdriver or even a flat pc of metal will work. Remove the screwnut and then you can remove the light switch. You will also remove the light ground pc. Remember to reistall the ground pc or your lights will not work. Hope this helps.
Found and removed the headlight switch nut with the handle of a spoon..ha. Thanks for the help.
