headlight switch revisited
rowingone
colorado
1964 conv
OK so this is a long shot but I was wondering if anyone out there had replaced their dash wiring harness and was willing to part with a small piece of the old one . . seems bubba had cut off the connector for the headlight motor switch and I dont want to buy and replace the entire harness . . . just need the odd little connector . . . I could hard wire it but it would be better this way . . also if anyone just happens to be under their dash today I need to know which color wire goes to which terminal on the motor switch . . I"m just not sure of the orientation based on the wiring diagram. Thanks in advance!
Give Electric Limited a call. I am not sure if they will sell parts, but it would be worth a try. I would also keep track on EBay. Every once and a while a harness comes up for auction.
If you do happen to find a used harness, I am in need of the connectors to the headlight motors. The plastic prong that keeps it secured in the round socket is broken.
Good luck!
Ray
Thanks Ray . . amazingly enough Lectric Limited had the connector . . $14.00 - cant beat that! The debubaizing continues!
