Hi everyone
i have a couple of headlight issues that I need some help with. First is headlight wink, where left light will not go down.
so i relaced the headlight actuator. Did not fix the wink. Upon further inspection, i think the HL gets me hanically stuck at full up position....i have to reach through grill opening to manually move the linkage, at which point it then starts to close by itself. So first problem is why does it get stuck up at full up position? Actuator is new and all vacuum hoses are new. What to do?
Second problem came when i replaced the actuator. When retracting to fully down position, it stops about 1 inch short of fully down. Why? I think that clevis pin was screwed down far enough onto Ctuator threaded shaft, so why it wont go down all the way?
are there travel adjustments that fix this, or..... ? Please help
Ernie
Ernie
