R
Rokin
Ignore this.. I'd forgotten to put a connector back on the junction box behind the battery.. doh!
Hi.. 1990 C4
Been having a few problems with VATS so cleaned all my CCM contacts & fitted a new radio over the bank holiday.
When I tested.. everything is working apart from the headlights don't popup, (they light up ok, but the motors dont engage at all).
Is there anything under the dash that I might have unplugged that would cause the problem ?
I cant see anything obvious other than a single earth wire that doesnt connect to anything, the wire is spliced into to the earth leading from a little relay thats something to do with the rear fog light (which is on a seperate switch) ?
I haven't used the headlights for months, so it might not be related to me disturbing the wiring.
Hi.. 1990 C4
