Headlights
Airforcevette
Georgia
1995 LT1 Black Coupe
Here's a head scratcher. I have a 95. The other night I was checking my lights. Without the key in the ignition, I turned on the parking lights. When I did, the parking lights came on, also to my surprise the antenna went up and the radio came on, ( the radio was in the on position). What could be the cause? Also, when I turn on the headlights, the left one moves up and down rapidly(like a bobblehead doll) .
Something has to be shorting somewhere, so if not through repairs then through deterioration. About all I can think you can do is disconnect the battery then start tracing every wire from the lighting looking for bad wiring, bad relays, bad grounds etc.
Good luck
