headlights
myron
manteca ca
2014 stingray
Some times the head lights don't pop up.Park in garage they work all the time. Go for a trip some times they will not pop up.
Any idea for a fix.
HI there,
Are you talking about only the twilight sentinel, or is this when you are using the headlight switch????
Allthebest, c4c5:hb
using head light switch.Some times it works 50% it does not.I think it may be A actuator for the lights
myron
HI there,
I would say that the input for the actuators may not be received by the motor relay actuator control box.
There is alot that may be possible, so I would suggest professional diagnosis in this case.
Allthebest, c4c5:hb
