Heat/AC controls
  • Thread starter Thread starter sumoboy
S
sumoboy
I have a vacuum leak in the vent control manifold for heat. Will others fit the 84'? (Full size chevy or others) I don't know if the dash controls are the same fit .;help
What style A/C controller ( auto or manual)
and the control head doesn't actually do any vac routing.. another box under the dash does that for the C-68
Need more details
Vig!
It's a manual one. The air just comes out of the vents,no defrost or floor. If I run vacuum to the lines for the defrost or the floor they both work. There is a vacuum manifold on the slide control.
ACDelco Part # 15-71414 C49
Ahhh the dreaded switch!
But back there.. is the vac line coupling as well maybe...just maybe your leaking at the line running behind the dash & not the switch!
Vig!
Vig...
Remember the source is off the plenum, and then down the firewall into the dash....plenty of places for a break....plus after a while that tubing gets brittle. And also the check valve is a possibility
Yes Eagle.... you are 100% correct
I assumed!
I thought the "Hissing" was com the dash.. that's why I went that way...
OOPS
Thanks again Eagle!
Vig!
