mcditalia
My Corvette never gets driven in the winter here in the east coast. Can i just take out the heat riser without making modifications (block off passages) in the intake manifold?
im also assuming that the heat riser moves back to the closed position ( outside lever in a horizontal position) and should move down ( vertical) when throttle is applied? When cold this lever will not snap back after being pushed down by hand.
