- Joined
- Jan 24, 2002
- Messages
- 229
- Location
- Binghamton, NY
- Corvette
- 1981Dark Blue Metallic & 2004 conv. magnetic red
My auxiliary fan is not working, new fuse and connections are tight. What is the best way to trouble shoot this problem? Disconnect the connection and put a volt meter in line, when the temp reaches 215 the heat switch should close and voltage be at the connector. Also where is the heat switch and how would I check that?
Chuck:confused
Chuck:confused
