9
92BamaVette
First thing is, my heater system is not getting very warm. The climate control operates fine. All the buttons work and vents change to the appropriate input. I have noticed that on hotter days the heater temp is hotter. The engine is still running at 200 degrees whether its a hot or cold day. Could it be the ambient temp sensor is sending a false signal? It takes the car 20 minutes just for the heater to get to room temp when set at 90 and will not get any hotter. I need more heat, winter is here. Also recently I had the BCM replaced, does that have any effect? Programming wise ?
2'nd question. Does a 1992 vette come with keyless entry? If it was an option how do I find out if mine has it or not?? Car did not come with a key fob.
I just bought this car wholesale. My first C4, nothing like my precious C3. I see that this car is a whole lot more complicated when it comes to diagnosis.
