Bill75
- Joined
- Jan 1, 2004
- Messages
- 698
- Location
- Somers CT
- Corvette
- 75 Coupe ZZ4, Brodix IK-180's, Headers,TK0-500
The attached pic is the rotary vacuum valve from the console that changes the function from heat to A/C, to Vent, etc. Each of the places where the lines attach are numbered and each line that attaches has a color code. There's only one way the hoses attach and I'm pretty sure they're correct but I'm trying to solve a heat problem so just to be sure.......does anyone have a drawing or table that tells what number line controls which vacuum actuator. I've looked on Bobchad's site but his 77 is different than my 75.
ALSO......As soon as I start the car my lower right kick panel actuator opens along with the fresh air vent (Console control is Off). This leads to a continual airflow in the car. My Vette shop says the kick panel vent should only open at max A/C to resirc the car air and the valve in the picture is defective. I replaced it with another (used) one and it does the same thing. Is that normal??
