Hello All, Garage Find? 68 Coupe
jonser
Alta Loma, CA
1968 Coupe
Hello All,
Well this is my first post! My cousin turned me on to his co-worker and golfing buddy that have been together for the last 35 plus years. The golfing buddy purchased the 68 coupe in approx. 1970 upon his return from Vietnam drove it on Sunday's (yeah right??) and then parked it in the early 80's. The last up to date license tag is from 1985 and has been sitting inside his garage with only approx. 52K. I purchased it in Feb and now it sits in my garage. The body is in great shape, needs paint, interior seats and carpet. The main and only issue (fingers crossed) is the steering column. From what I was told the 68 steering column went bad (telescoping?) and at the time 80's he could not find a replacement so he, started to reinstall a 70's steering but, never finished it and now it sits.
The only research I've gotten to is on the front right engine pad V0305HP, Casting date C 2 8, and Engine Block 3914678. Missing the air cleaner bottom and top but, everything, I mean everything under the hood is all still in tact and original.
Any suggestions on where to go next? WP_20131231_001.jpgWP_20131231_021.jpgWP_20131231_001.jpgWP_20131231_021.jpg
Welcome to CAC!!! enjoy!!
Welcome to Corvette Action Center and Congratulations
Welcome aboard, congratulations on you barn find so to speak, now is your chance to bring a classic back to life. I would start with the engine and drive train, appears it's been setting around long enough that it could be locked up or at a minimum needs rebuilt, parts are out there you just have to look, search the internet. Depends on if you was going to do a body off restoration, which is what I would do, or just clean it up a bit and get it running? Brakes, brake lines, tires, transmission, clutch etc if it is a stick, electronics, battery, on and on, it's going to be quite a challenge but well worth it when you get done, but it is going to be a lot of work!!! Keep us posted on what your going to do as well as the progress, have fun :happyanim:
-Bill
