Help 1959 Wipers wont turn off
NCVetteDude
North Carolina
2 - 1980s, 56 Studabaker, 71 Ghia
Help,
Just got my new (new to me) 1959 and now the wipers wont turn off. They go from high to low fine but dont seem to shut off. I found the cable on the wiper motor and it is pulled all the way back.
An idea what else to try?
Thanks,
Clint​
Moisten windshield, keep it wet with a spray doing this work-
loosen up cable from slide controller so you can work it by hand.
turn on ignition
Note there is no electrical connection to dash, only a cable. Working the cable and slide activates the wiper motor which always has power going to it when ignition is turned on.
work the slide back and forth by hand, keeping windshield damp
wipers should operate and if you're lucky, will park. timing the park during a down stroke may help as well.
If it parks ok, reconnect cable accordingly so it will park.
Don't forget to turn off power when done.
If not, you'll have to remove cover and work on contacts. Do a forum
search.
Motors and switches can get real sluggish if not worked occasionally.
Contrary to popular belief, these cars will not melt if driven in the rain. But you will want to bring some towels with you.....
Happy cruising!
Thanks for the info. I was able to slide the plasic slide over and get them to park so it looks like it is just an adjustment issue.
Thanks again!
NCVetteDude - here are some photos of the wiper motor assembly. What needs to be done has already been stated. Just lube and adjust.
Carolinas Chapter Solid Axle Corvette Club - CC SACC. Please go to the website at www.solidaxle-carolinas.org and check out our Carolinas Chapter that was started this past January. New members are very welcome. You don't have to have a solid axle Corvette to join.
A great group of folks if I don't say so myself. :D NCVetteDude check out the site...are you in the Raleigh area and do you have a red Vette?
Regards,
Fred
Fred,
Nope we are in Greensboro and the car is black with Silver Coves and Red interior.
Thanks,
Clint
Clint,
Nice color on your C-1.....we have a few members over in Gboro.:)
Fred
Since you are talking about wipers ,where does wire for wipers connect. Thanks Ace
