help 1992 code 63
church
New member
callahan
1992 c4 lt1
I have replaced o2 sensors had ecm checked ecm good . I drive the car for about 5 miles & ses lite comes on . do the paper clip trick & get code 63 . all wireing check ok . I need help . thanks for any info that can point me in right direction .
Code 63 is a fault with the O2 sensor for the right bank. It sets when the rt. side sensor voltage stays between 350 and 550 Mv for 60 at least 60-sec after a 2-minute run time.
It can be caused by an open in either the rt. sensor signal line or the ECM ground. Also, it can be caused by a faulty ECM.
Since you replaced both sensors and you say the ECM is good, I'd look for an open in the right-side sensor signal line or and open in the sensor ground.
what is the best way to check signal line & sensor ground
