- Moderator
- #21
- Joined
- Nov 9, 2000
- Messages
- 7,556
- Location
- Edgerton, Ohio, United States
- Corvette
- 1959 black 270hp (9/2/69), 1981 Beige L81(10/20/80)
As to the tach question I really don't know. If I had an electric tach malfuntion it would either quit altogether, stick and jump or lag behind. I have had oem and aftermarket lag behind. Never had one read fast but I suppose it's possible. Also there have been volumes written on the problems associated with mechanical tachs on every Corvette site and in every Corvette magazine.Ken Anderson said:The reason for the difference is the El used an electric tach and the Corvette used a mechanical tach, which is the more accurate of the 2. It is unlikely that a 454 in 1970 would turn 7000 rpms and hold together for very long. Your 67 was too lean from the factory, and that caused your plug problem.
Since a mechanical tach is basically the same mechanism as a speedometer head it is subject to the same shortcomings as to calibration and maintenance. If the cables and gears are in good shape, lubed properly and and not kinked or worn then it should work as it was intended to by the engineers. Sort of goes back to the statement on the old ignitions. If it's well maintained it will get the job done. One of these days when I'm feeling especially masochistic I need to pull the cluster from the '59 again and send the tach in to be recalibrated. It worked within a tick of my engine tester until it broke then the shop that fixed it got the cable speed wrong when they recalibrated it.
The carb on my '67 was a 780 vac secondary manual choke over the counter Holley. It was the only non-stock part. I always suspected it as being a little too rich for stop and go city driving but it never smoked out of the Hooker side pipes. Realizing that headers tend to lean out an engine I probably should have had it hooked up to a sniffer to be sure.
Tom
