J
jjw94
OK, Here it goes. I go out to start the car, starts fine, and I drive it for about 10-15 minutes, then shut it off. Wait about 10-15 minutes and car will not start. If I wait for about an hour to an hour and a half, it will start. Also occassionally as I shift through the gears, some hestitation occurs, mostly in first and second gears. Had it to the GM Dealer, they replaced the coil. (Found a broken wire) That did nothing to fix the problem. They checked fuel pressure, it is fine. They suggested the problem could be the distributor. To install a new distributor was going to be about $1600, and they would not gaurantee the problem would be fixed.
Can anyone offer me some suggestions on this problem ? Could it be something else ? Desperate for some help and advice from my fellow vetters.
thanks,
jjw
thanks,
jjw
