- Thread starter
- #41
D
DMGroh
DMGroh said:Just recently, I had a violent mis after running in traffic for an hour. It would only start fully floored, and even then it was very rough and I had to keep the rpm's up to keep from stalling. It was difficult to get the rpm's low enough to get in gear (Automatic) without either damaging the tranny or stalling the motor.
It's up on jack stands now getting a new opti & wires, as well as cleaning & testing every electrical contact, connector & ground I can find.
Just got inside my opti and found the source of my problem. 1 of those tiny torx screws holding the rotor backed out and was laying around inside there. With only 1 screw holding the rotor, it can flex quite a bit and caused the violent jerking/miss I had. The screw that fell out was not nicked or beat-up, so I believe the problem was from the rotor flexing. There were no carbon traces, but the contacts on the cap were screaming for replacement. Sure glad I went in there.
Question for the "Wiser/Better Informed/Experienced more problems than I have (yet)": Should I take out the rotor screws from the new GM opti and loc-tite them? Would they already have loc-tite? Any advice here?
Comment on a 10 year old rotor. I was surprised at how much the plastic had deteriorated..it was about to break into pieces and there were no signs of blunt force trauma. If you guys are upgrading to an aftermarket unit and decide to keep the rotor in there as a spacer, you might want to think twice about re-using the old rotor.
