Probably it is either the master or the slave has gone out. Check it out. Best to replace both at the same time. Usually if you just replace one the other goes out after awhile. That's what happened to me. First the slave then a little later the master. Triple check that the booster is working right, when mine went out the pedal was hard as hell.
As far a it being a lemon, they all have therse problems. I had an 84 and now an 89 and things go out all the time. I am just used to it. My 84 was worse because the parts that went out were very expensive. The rack and pinion and the transmission (twice). Since I got the 89 it seems more normal things quit on me. Starter, alternator(twice), various sensors, cat and pre cats, o2 sensor, injectors, batteries(2), clutch, brake booster, master and slave, seat motors, seat foam and leather deteriorated-so new seats, door and hatch seals need replacing, throttle body needs replacing(shaft is worn and air is leaking in causing idle problems, egr(twice), fuel pressure regulator(twice), various relays, neutral start switch at clutch pedal, brake light switch, outer window seals(both L and R), bose radio going out needs new amps and head unit tune up, window switchs, winshield washer switch, AC clutch, AC contro unit, HEATER CORE (I did this myself------never again, almost killed me and took ALL day), needs new shift lever boot(leather is deteriorating), E brake mechanism replaced, needed new distributor and module and pickup and pig tail, had to have Bilstein rebuild my FX3 shocks($100.00 each) and now one of them leaks and needs rebuilding again, FX3 selector needed replacing, relays in the ABS syster went out, and some other stuff needs fixing now.
I got the car with 44 thousand on it and it has a little over 125,000 now. I have enjoyed every ride I've had in it and still today love to drive this car. It handles like a go kart and has the pick up my 66 GTO did. Did I mention that I love this car?
