A
AUSSIEVETTEMAN
Hi everyone.
I noticed a coolant leak the other day and tried to find the source today.
The coolant is leaking onto the fuel pump and drips off the bottom of it onto the floor. I have checked all the hoses for leaks, but these are new Coolflex hoses and they only have rubber at the ends, as they are a copper hose. The water pump is new and the heater is not connected. There are no trails of white dried coolant on the pump, hoses, radiator or around the thermostat housing.
I have a bad feeling it may be the whelch plug behind the engine mount as it also drips from around here.
It only drips after the thermostat has opened and the water circulates trough the engine.
What do you guys think, have you any tips?
The engine temps are maintained at 160 degrees and it doesn't get hot. Mind you, I do have a big block radiator in there looking after things!
Maybe it's time for the engine to come out?
Tony
Tony
