Help Cragar wheels on a 1975 Vet
Stage Left
Long Island NY
1975 Corvette/ Stingray
Hi all
Need a little help, I have a 1975 Corvette/Stingray
I want to use Cragar Rims stock vet size 15X8 S/S super sport. My problem is I don't know what backspace to use for this rim, also do I need to use a spacer and if so, what size spacer do I need. I was told the rim could hit the brake caliper if the spacer was not used "Not sure" Any Data out there!
:bash
Tom.
Why not call Cragar and ask? They'll know what they fit and what they don't. Spacers are a BAD idea - they dramatically increase the shear and bending loads on the lug studs under acceleration and braking.
Thanks for the reply. I did email Cragar Two times on the question, with No reply.
Tom.
i don't remember what backspacing i got but i'm using an inch spacer on mine. i'll see if i can find the box they came in.
Thanks all, for your help.
I did receive an e-mail from Cragar
The cragar wheel should be a S-S super sport 15X8 rim with a 4 1/4" backspace
model number 61815 also needed to install wheels. Must use a 1/2" spacer Cragar Kit model number 29200. Must fit test rim before mounting tire, make sure caliper clears rim.
Your red vet looks great. What size tires are you using???
Tom.
Tom.
thanx. 225/60/15 fronts 275/60/15 rears
