help dash dead
  • Thread starter Thread starter dramo1
D
dramo1
hi..drove the car all day fine..went to get some coffee came back in car dash was not lit signal lights were lit solid but did flash when i put blinkers on also the brights indicator light is on and it shuts off when i put the brights on..i checked the fuses all good..the cluster is working fine just no lights.
1st--check the bulbs--everywhere connected with the affected area. 2nd--check the connections and wires. Since it happened so suddenly, it could be just bulb problems. Look inside the bulb sockets--see any corrosion? If so, disconnect the battery and then use an eraser to clean the contacts. Hope this helps.
