Happy New Year
My 86 failed 2 exhaust emission test, listed below are the test readings, and some results a friend and I discovery from a "SCAN" tool test.
Hydrocarbons Carbon Monoxide Oxides of nitrogen
HC CO NOx
standards 1.8000 GPM 30.0000 GPM 2.8000 GPM
tested 2.4400 GPM 66.0517 GPM 1.0944 GPM
results FAILED FAILED PASSED
I was a bit surprised because its running great, no codes, no driveability problems, good throttle response...etc
Results from "SCAN" tool diagnostic procedure, tested with engine at 'NORMAL" operating temperature (of course).
Coolant temp reading above 90C
Oxygen sensor reading 400-500mv (when first checked showed above 600mv, but after monitoring it dropped into the 400-500mv range.
OPEN or CLOSED loop: indicated it was always in 'OPEN LOOP'
never went to 'CLOSED LOOP'
Were do I go from here??? Thanking you in advance, for all your help!
Thom
HC CO NOx
Thom
