B
bowmanm
I bought an 87 convertible in July. When I bought it I knew that it needed tires and some interior cosmetics. I took care of that and had the transmission and radiator flushed. The car has 53,000 miles on it and is real sharp looking. Since I flushed the radiator I developed a coolant leak. I found that the water pump was leaking and since the car is 17 years old I decided to replace the radiator hoses, radiator and thermostat along with the water pump. After doing this I found a new leak coming from the u-shaped throttle body hose. I then replaced it. Today the weather was nice so I fired her up and ran her around town. When I got home I discovered a small puddle of antifreeze on top of the intake on the passenger side, just to the right of the front injector.At first I thought it may have been left over from changing the throttle body hose. I cleaned it up and started the car again to make sure. After it ran a little bit the puddle started forming again, slowly. Could this be from the intake? The throttle body hose is not leaking. I am thinking that I may need a new intake manifold gasket because on the drivers side there is a small amount of oil on top of the manifold around the injectors also and a small amount on the back side of the engine.
