help, I can't see where I've been
  • Thread starter Thread starter aoriii
A
aoriii
I've got a problem with the rear-view mirrors on my 85 coupe. Sometimes when I get in (no pattern here), my rear-view (exterior) mirrors have 'drifted'. Instead of looking behind me, I'm looking at clouds. Both of them seem to do it independently. :confused
Has anyone seen this before? Is it a known 'issue' like the digi-dash?
I'm hoping someone can offer a quick fix (short of disconnecting the motor).
thanks for all the help so far.:upthumbs
btw: Rob, if you read this...Great job on the board...keep up the good work.:BOW
I have a similar problem with the side view mirrors on my '89. I look forward to hearing the advice you get.
Not that I'm aware of. Sounds like the motors in the mirrors might be weak; does the switch control them alright otherwise? :confused
In my case the motors seem to work fine. When I close the door or go over a bump they drift off their set position.
Doc
I don't think there is any way of adjusting the tension on them. It must be a weak motor that allows them to drop. :confused
_ken :w
motors
The motors seem t be fine...at least when I adjust them from in the vehicle. And they don't drift all the time, but probably 50% of the time, sometimes I'll notice they've drifted while I'm driving, but I never actually see them move.
my 84 does this too. the driver side drifts down. i dont know why either....
When I bought it several months ago, my 1995 did the same thing. When I closed the door it would move. I looked in behind the mirror and noticed one of the screws that hold the mirror in the housing was missing. I replaced it, and now it never moves unless I operate the control. :)
Good luck...
-Dave C.
Plastic 'fingers'...
I worked a little bit at a mirror supplier. One of the quality problems was not the moters (only about two or three suppliers out there) but the way it actuates the mirror surface. The moter has a drive screw attached to it. The moter then drives a multiple prong "clip" that is attached to the mirror. Over time these "fingers" wear down or weaken and void it's functional objective (keeping the mirror in place [your issue] OR adjusting the mirror)
What I don't know is how to replace just the "clip".
ROFL This is one of the reasons I called my car HAUNTED with the vanity plate and everything hehehehe
Mine is Drivers side and looking to the stars
