HELP!! I've lost my Key
  • Thread starter Thread starter 84Vette
8
84Vette
While working on my tires i broke the Lug key i need some help what to do?
84/vette,
Check out this past Thread pardon the pun.. couldn't help myself :D
There is a lot of good information contained in it and it may provide you with a solution to your crisis ;)
Rare Thanks for the info but that post refers to Mcgaurd and mine is not them but i am open to more suggestions even if i have to drill them out i want to get them off
You'll damage a socket, but you can get it off by hammering an old socket onto the nut. Thieves do it all the time. ;)
_ken :w
actually you can go to the parts/tool store and buy a Gator Socket. Its liek 3/4 big but its filled with little pins in it to grab near anything.
Normally I hate this thing its junk to work with but in your case Im betting it'll solve the problem so you can get a new set of lockers put on with a new key.
Even if they aren't Mcguard, the brand or the mfr. should have a phone hotline ? Or contact a local Tire/Custom Wheel shop and see if they have any suggestions..
I'm sure you're not the first person to have this problem with the brand of Lug Locks you have ;) by the way what brand are they?
BudD
:bu :w
Rare
the Lugs Locks Came with the car And I don't know the brand as of yet they are smooth all the way around with little nobs(like 8 or so) on the end of the lug near the rim
Can you post a pix?
That way we have a better idea what your talking about...
Your saying there isn't enough of a lug sticking out to POUND a cheepie socket over?
Next would be take it to a tire store... those guys have ALL the tricks!
Vig!
I'm told that Snap-On makes a tool that removes any locking wheel nut. It has hardened ridges on the inside of a socket which you pound into the nut. The nut's useless after though. Good Luck!
that's fine if it destroys the nut because i don't need the anyway if someone want to steal my rims they will spend a good 15 min pre wheel as is. I will look into snap-on they come to my work weekly
