Hello everyone! I have a 1981 with the original L81 (190 HP) in it with 87,000 original miles, side pipes but no headers. Other than the side pipes, everything else is original, decent shape. Today I started it up and let it idle in the driveway, hood open. After about 5 minutes I heard a loud tapping or knocking sound as if metal against metal around the motor. No smoke from exhaust, oil level good and clean. It sounded like it was outside the engine, not inside it. I shut if off and let it cool. I later started it again and there was no sound but I didn't let it run long this time. I called my mechanic and he just said to "bring it in, Ok to drive it". I'm not a mechanic. My questions are: Should I drive it the 6 miles to a mechanic? And, in your experience, is this likely rod bearings or something major requiring expensive work or a new motor? Or maybe just a timing belt tension deal? In a worse case scenario, where's the cheapest place to get a decent rebuilt or new 350 crate motor and at what cost? And finally is a crate motor a better route to go than having a mechanic just rebuild it? I'd have to have a mechanic put a crate motor in anyway, can't do the job myself. I feel inclined to just upgrade to higher HP (close to 300 or better) in a crate if the cost is about the same as a rebuild. I see a few on the internet for 1995.00 or 2995.00 for the same engine turn key, although I believe the distributor and carb are good for a swap. Any guesses? Any comments or suggestions would be greatly appreciated. Regards, Bill
