D
DigitalFalcon
I started last week changing the heater core and following the instuctions from the posts. (Doing it the short way)However I pulled my neck out of wack last week trying to balance upside down on my head. It was almost back to normal this morning so I tackled it again. I got the seat out. Cover off. ECM out. Wires out of the way. Unhooked the heater vent control and moved it out of the way. Took out the cross brace. (WHAT A PITA!) Unhooked and moved the ducting out of the way. Now, I just undid THREE 7mm bolts that I could find holding the front heater core shroud on. I was able to pull it a few inches forward to see the core. YEA!!!!. Anyway, My question is: Are there more than three small 7mm bolts holding the front shroud on? 'cause I am pulling gently and it doesnt want to come off. I dont want to pull too hard in case there are some more bolts up top that I cant see. Any ideas? Are there more bolts up top. Help.
Thanks - Falcon
BTW - The foot well is not made for someone 6'4" and 300 lbs to lay in!
Thanks - Falcon
