I have a couple small pin hole fluid leaks in my speedo cable lower end (37 years of rubbing)
I have a 2 peice cable. At the trans end I have about a 2 foot section that couples to the cable coming down from the dash.
I can't seem to find a reference of replacement for this 2 ft section. Only a 71 inch one peice.
Replacing only the short cable would make life sooooo much easier.
Was this a factory set-up???? 1969, ~8100th off the line (Nov '68)
Question # 2 - Should trans fluid be able to get into the lower end of the speedometer cable through the connection of the trans? Do I have an "O" ring problem in the trans?
