C
curtis
Finally installing a 700R4. I have lost track of the correct angle the engine had before I chopped out the tranny crossmember. I believe I need to set the engine angle the exact opposite of the pinion angle. Is that correct? What is the correct pinion angle? Will the driveshaft angle also need to be addressed? I don't even remember if the engine was level in the car. Should it be? How do I measure all this stuff? Really want to get it right the first time. Sure could use some help here!
