sxyvet
- Joined
- Aug 3, 2005
- Messages
- 248
- Location
- Dandenong,victoria-Australia
- Corvette
- 1991 ZO7 coupe, 6 speed,red on red w/most options!
hi there guys,
how are ya!
i have a 1991 L98 vette!
any way i finally got around to installing my super ram this weekend!
mind you, it took all bloddy day to install the dam thing!!
i went to start the thing and no fire!
it cranks over but no start!
i checked fuel preasure guage and it has no preasure at all!!!
i have a fuel adjustable fuel reg and new diaphram gasket just intstalled when i put the super ram on/togeather.
i tested for spark which it does have!
i also cheked for codes,it has a code 13 and code 46, which is oxygen sensor and v.a.t.s!
i checked and adjusted the t.p.s to .54 volts also.
i re done the plug leads in firing order of 1-8-4-3-6-5-7-2 as well.
when i removed the distributor i made sure i marked which way every thing was facing i thought anway!
while i was cranking over engine i moved back and forth a little the dist as not sure what timing was at!, no luck.
when i installed dist i lined up oil pump slot with dist shaft/gear!
but may be i still made a mistake!
i heard that the oil preasure switch is not working , the car wont start,is that correct please?
also could it be a fuel pump fuse?,where is the fuel pump fuse located also please?
when i turn the key i dont hear the fuel pump prime up also i noticed?
any ideas/help please guys??
what can i do?, i need to get it started and i have left my sevice manulas up home at my parents so i cant acces for info!
i hope to hear some info/help from you guys please on what to check and look for!
cheers and thanks!
glen
how are ya!
cheers and thanks!
glen
