olouieo said:
My floor mat seem slippery, at first I thought maybe I steeped on some oil, but I cleaned it. Today I saw some more on the pedals, My first thought is maybe is the oil gauge line. I am not sure. Well it got dark and I could not search anymore. Is there anything else it could be or do you think is the oil gauge line. If yes. Is it easy or difficult fix? Thanks.
Contrary to what most people assume, the oil pressure sending line doesn't flow a huge volume of oil, dispite the pressure readings. It barely dribbles out when the engine is running, so looking for oil spray or mist to isolate the source will not work. Look instead for small, regularly timed trips, and the oil is usually not very dirty because once that line is full, and has no trapped air, it doesn't circulate with the rest of the engine oil, but remains in that line. Yes you may get some dark coloration if you have a leak in the line because the engine oil will continue to feed the line, thus replacing the clean oil, but for the most part it will remain clean oil.
Somebody already mentioned the possibility of the master cylinder rear seal seeping, that would be where I would begin looking also. If you have power brakes, then the booster would not allow the seeping to go further back than the booster tank.
Somebody also mentioned coolant, there are no coolant lines on the drivers side that could provide a source for a seep or leak inside the vehicle.
Just checking for one other possibility, have you recently lubricated the clutch and/or brake pedal pivot points? If so, that could be the source, over zealous oiling.
vettepilot
