- Thread starter
- #21
Yes. Actually im looking forward to getting the plenum off, i will do things step by step as advised, Im not going to rush.
I just received this car. The owner got it in trade at their chevy dealership. I had it shipped. All the work done was in the dealerships shop.
They did the following. to the engine. Complete gasket set,pulled the oilpan replaced main bearings (showed wear) and oilpan gasket. New starter, so the plenum has been off, all service was done spring 2007 then stored car.
I will get the plenum off. Is there a need to drain the coolant?
old guy trick to find vaccume leak .propane torch , put a 3ft sec of 5/16 hose.turn car on . thenturn on the torch (dont light hehe) runthe the end of the hose around suspect ares when you find a leak the rpms will rrise .hope this helps
