P
photovette
Specs: 1977 355 motor (1yo) TH350 transimission.
It started abruptly about 2 weeks ago and has become slightly worse.
The car feels like it's running on seven clinders.
It's more pronounced when the engine is under load and in a lower gear. It is most noticable when I have the car in 1st gear then coast in gear from 4000rpm.
I can hear the vibration in the exhaust tone--kind of a rapid burble.
The vibration goes away when I place the car in neutral at speed and coasting.
The car starts and idles smoothly.
I've noticed a drop-off in power.
The vibration is constant at 70mph.
There is no abnormal slippage from the transmission showing up on the tach.
I replaced the plugs, plug wires and distributor cap/rotor to no effect. All plugs looked normal. I set the timing, idle mixture, and secondary air valve. I made sure no plug wires were crossed. Changed transmission fluid and filter. No help/no change/no dice.
Any suggestions? I hate to take it to the shop!
